I have a situation where I have to usean end mill with a .015 corner chamfer. In pro man tool manager the only place I see to get a corner chamfer is with a chamfer tool. The problem is with the rigid tool use in pro man they do not allow you to use a chamfer mill to side mill. Am I missing something, what can I do to get a milling cutter with a corner chamfer that will side mill am I missing something?
