Show NC Sequence CSYS in Model Tree
ScottJohnson
Is there a parameter that can be added as a column in the model tree that will show each NC Sequence coordinate system used?
2 REPLIES 2
I don't know of any such column or whatnot to show which CSYS is used by a particular NC Sequence. I'd hoped that it might highlight the pertinent CSYS when I picked the NC Sequence from the model tree, but no such luck.
Guess the only way to be absolutely sure is the tedious Edit Definition nightmare.
Thom
(To:ScottJohnson)
The Process Manager will show which CSYS each sequence uses. Just enable the "Orientation" from the "Mfg Setup Items".
