Surface milling by angle gone?
blong
Using Creo 5.02
So we use to be able to collect many separate surfaces to like ribs of open pockets and machine them in one seq. and use cut angle to machine ramps or ribs. Now that option is gone and even classic surface milling is gone. This is a huge loss does anyone else see this? Is there a workaround so we don't have to cut-line everything and waste hours of time ?
2 REPLIES 2
MartinHanak
(To:blong)
is following option included in config.pro ?
enable_classic_nc_steps  yes
Martin Hanák
blong
(To:MartinHanak)
Yes this is enabled and still no classic surface milling.
I have found the work around. It has been switched to seq. Conventional milling and works rather nice.
