Turn-Grooving Tools
mdenicola
Turn-Grooving Tools
Is there a kind soul out there who would like to help me set up the turn-grooving tools?
Can't find out how to setup TIP, OFFSET CENTER and so on.
mdenicola
(To:VladimirN)
Yes , That's the explanation but to me it's still not clear how to set everything.
Let's show an example.
This is my settings:
 The TIP csys is at the center. Nose radius is ( 0.2 mm)
Insert Width is 4.1
Nose Radius is 0.2
Let's say I need to cut this:
 Should I make a profile at 4.1 mm distance from the part ?
Like this:
Material direction to remove:
offset cut checked like this:?
 How to set the OUTPUT_POINT in the parameters dialog box?
Thank You!
