Using Creo Parametric for CNC PCB Milling
FL_10347392
2-Explorer
Hi All,
I am investigating the possibility of using creo parametric NC Milling to program a table top CNC Milling machine to machine PCB test boards that were designed in a PCB design software like KiCAD. Is this something that is being done with Creo currently? We would use this for rapid prototyping of test circuits by buying PCBs with a top copper layer and then machine away the copper between PCB connections.
What would the workflow for importing the top layer and then programing the milling?
Thanks!
FYI, I am currently using Creo 8.0 with Advanced Professional Licensing.
0 REPLIES 0
