Wildfire 4.0
ptc-3125048
Wildfire 4.0
The online demo shows how to Insert CL Commands into the NCL file for Trajectory Milling using: Tool Motion/Insert/CL Command then typing in the CL Command text. This works great for trajectory milling, but how do you insert CL Commands for other types of machining processes? This is critical for complex machine functions such as multiple process machines MILL/TURN multi-spindles etc.
Hello, While you are working within the NC Sequence select the Customize option. This is found one option under Play Path in the Menu Manager. Good luck, Joel Joel Cartwright Instructor at EAC
Joel, That worked. Thank you for your help. I am providing postprocessor support for a Mazak Quick Turn Nexus 100-II MY Turning Center / Mazatrol Matrix CNC(Live tooling, programmable tailstock, air blast,part catcher, programmable CXYZ axis, polar interpolation and angle drive heads) Best regards, Larry Larry Jones Consultant Mfg. Engr. NCData Services www.NCDataServices.com
