can windows 10 supports EMX 9.0?
adeshmukh
Please tell me can windows 10 supports EMX 9.0
17 REPLIES 17
Refer to Hardware Notes - Creo 3.0 at http://support.ptc.com/WCMS/files/161492/en/creo3_hw_notes.pdf,  Windows 10 is supported on Creo 3.0 M060 and later. And EMX 9.0 is compatibility with Creo 3.0, so Windows 10 is supported by EMX 9.0.
By the way, install the latest EMX 9.0 M010 is a preference choice.
adeshmukh
(To:tshen)
I installed EMX 9.0 M010 but it was not run.
did you link EMX 9.0 M010 with Creo via protk.dat file ?
MH
Martin Hanák
Please tell me how?
I am trying but not done.
Please help me out.
did you read CS37254 article mentioned by Tao Sheng Shen (see attachment)? Do you own EMX license ?
MH
Martin Hanák
Yes, I read that article & follow  the procedure mentioned in the article but it shows me error message   Foreign program "Expert Moldbase Extension 9.0 ""failed to initialise: error PRO_TK_LICENSE
What it means
do you own EMX license ? This means did you buy EMX license ?
MH
Martin Hanák
Yes, I have.
I can't see your license file and Creo installation, therefore I have no other idea what to do. Please contact PTC Support, if you are active on Global support.
MH
Martin Hanák
ok
To load EMX in Creo, you need to set config.pro protkdat to <EMX 9.0 loadpoint>\bin\creo3\protk.dat or refer to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS37254 for detail
Ryan Kelley‌: Can you please move this to the Group Expert Moldbase Extension - EMX
Kind Regards
Thomas Schneyer
B&W Software GmbH
So far EMX 9 is it is not officially tested with Windows 10.
Still there should be no problem with it. You can simply try to install and run it.
Regards
Thomas
Kind Regards
Thomas Schneyer
B&W Software GmbH
Hi Thomas,
I tried but it wasn't run.
we have tested EMX 9.0 with Windows 10 and we could not find any issue.
Regards Thomas
Kind Regards
Thomas Schneyer
B&W Software GmbH
Hi Thomas,
Thanks for the reply and I will try it once again.
Akshay
