horizontal milling????
asifcad
is it possible to make nc programming for horizontal milling????if yes then how i do it....please help
BenLoosli
(To:asifcad)
Yes, the key is establishing the proper coordinate system for the direction of the spindle.
Creo should be capable of doing up to 5-axis machining.
asifcad
(To:BenLoosli)
Thanks Ben have you any sample mfg file ..of horizontal milling I want to learn it...
Asif
