make stop for tool change default in material removal simulation
jferguson4
I always want material removal simulation to stop where tool must be changed.  How to make this a default?
SteveLucas
(To:jferguson4)
If you select stop at tool change from the view menu then do a save of the settings it will save that for the next time you run material removal simulation
2 REPLIES 2
SteveLucas
(To:jferguson4)
jferguson4
(To:SteveLucas)
thanks much.
