pressure load surface visualization...
PAULKORENKIEWIC
I often have to apply pressure loads to fairly complicated internal
passages where it is relatively easy to "miss" some of the surfaces.
Typically, I will turn off the simulation display and go into wireframe
to try and confirm that I haven't missed any surfaces, BUT this doesn't
always provide an absolute assurance. So, I am wondering what others
do? IS there a way to control the color of "selected" surfaces when
applying the pressure load? The default is a "pale red/pink" that
doesn't always show up so clearly, especially when your part is complex
enough that you cannot isolate the surfaces (by that I mean, that there
are some surfaces that no matter what orientation you look at them from,
there is another surface with pressure behind it). Seems like if this
was a darker color it would be easier to spot missed surfaces.
I remember there was a way to toggle a group of selected surfaces to a
wire mesh display during the selection process but I think that was only
in modeling mode. Or was it?
Oh, and yes, I try to use seed/boundary selection aids when
appropriate...
Thanks in advance...
Paul Korenkiewicz
FEV, Inc.
4554 Glenmeade
Auburn Hills, MI., 48326
0 REPLIES 0
