"Trochoidal Turning" in Pro/NC
DanielSantos
Hi folks,
After some months investigating solutions I learned a lot about other
CAM systems and how they do things. I also learned some nasty marketing
tactics employed by CAx vendors and that sometimes the things are
wrapped with a nice cover but in the core they are all alike. That being
said, I created a small video showing Creo Elements/Pro 5 profile
turning toolpaths applied in a complex groove so that you can get the so
called "Trochoidal Turning" effect such as shown in Unigraphics NX and
Sandvik video. Please check this out at Sandvik website:
http://www.myyellowcoat.com/solutions-machining/cam-programming/trochoid
al-turning-calculator/
http://qstream-wm.qbrick.com/01247/tooling/Sandvik_Coromant/Turning/Troc
hoidal_turning.wmv
This video below shows how to make this in Pro/NC or Creo Elements/Pro.
It can be done in all Pro/NC versions as well. "Trochoidal Turning" in
Siemens NX is NOT a dedicated toolpath as it seems but rather a series
of profiles offseted with reversed lead in / lead out moves / cut
directions.
YouTube link (High-Resolution)
http://youtu.be/FPERyMN54g0?hd=1
Enjoy it!
Daniel
0 REPLIES 0
