Is there a way, other than inserting a CL command in Tool Motion, to force each sequence to force out ROTATE even if it does not need to move? I'm trying to do it with my post, but I get the last rotation or a double rotation. By using the CL command, I have to put warning comments if anyone else tries to resequence anything.
Hello
if you use G-post try
MODE/YAXIS,[ON-OFF-AUTO]
Regards
