Tool library Mill Turn machine & eccentric turning sequence
nirreitman
Hi all.
does anyone have experience/knowledge on building tools for milling/turning?- preferably 3d tools to be used in Vericut later on.
also any info on eccentric turning sequence would be great.
Hello Nir,
maybe if you could specify your questions regarding eccentric turning sequences a little more, it will be easier for someone to assist.
Usually "eccentric" refers simply to workpieces that are not rotational symmetric about the machine axis, like for instance when turning a section of a crank.
So the whole process itself doesn't look different from the Creo side, just the location of the workpiece and hence it's rotational axis is eccentric to it's principle axis.
Gunter
