How to combine several operations into single NC file? (For ex. Facing, End and Volume milling in one NC file)
You can use "Save CL File for set" available under "Save a CL File" menu.
Save CL File for set > Create > Set Name > Select required sequences > Done Sel > Output > Select Set > File > Done.
I hope this will help.
