Have been working on a file for a couple of days, but crash resulted in 0kb file! Is it possible to recover/restore the file??
The short answer is: No.
There's no data in a 0 kB file.
If you hadn't followed the 11th commandment (Thou shall make backups) yet, this should be the trigger.
