Luk:
Yes, that worked.
Initially it did not,
I Found that I had to disable PCmatic. "SuperShield" to allow the pop-up window to appear.
Paul
If you just installed Prime 8, and did nothing else, you have the Express edition: That is Prime with the limited features that you get after 30 days on trial with with the full feature set.
In order to get your 30-days trial with the full feature set, you have to apply for the trial license. I believe that is possible using the license interface:
Click the very top left 'button', the circled M. Then choose 'Options' from the menu and select the license tab. In there click the button "Get license' and then ( I assume) you can opt for a trial license.
Yes, applying for the trial licence should get you to enter this workflow:
Luk:
Yes, that worked.
Paul
Thanks for sharing your solution to this issue.
