Starting from the 7th version of Mathcad Prime you can use the built-in converter (before the installation process, it is necessary to select it among the installation components).
thank you for your answer, but I have already installed the tool XMCD, MCD converter, but it doesn't work with the file that I need to convert..
I think that the problem is the file itself.
You can download the file at the following link, if you want to try the conversion:
Many thanks,
Matteo
You need to open all hidden/password protected areas in your worksheet..
