Can I install Mathcad Prime 7 and Prime 9 on the same machine?
VijayN
8-Gravel
Hello - Please let me know if it is possible to install Mathcad Prime 7 and Prime 9 on the same machine.
Is there any technical limitation / restriction imposed by the PTC installer ?
Vijay
BenLoosli
(To:VijayN)
I do believe it is possible, you just need to use different loadpoints for each install.
I know when you need MathCAD 15, it must be installed before you install any versions of Prime.
