Can't find how to install Legacy Converter
ptc-1827700
2-Explorer
I am using Mathcad Prime 7.0 7.0.0.0
I can not find the installation for the Legacy Converter. It is not enabled in the Mathcad Prime program and when I run setup, I do not see the option to install it as described in the help website.
Here are the errors that I faced
None
2 REPLIES 2
rpathare
(To:ptc-1827700)
Hello @ptc-1827700,
Could you please re-attach the error messages you get (if any) as they are not attached.
RohitP
I was able to find how to install the legacy converter for MathCad Prime 7.0. It was indeed in the Setup routine, in the section on Customize Applications.
I now have it installed and working.
