This is a users forum for Mathcad/Prime, so we cannot help you with license purchasing.
Do you need the full functionality of Prime for your course, or can you do with the limitations of Prime express (which is what the functionality will drop to after 30 days)?
If you need symbolics, programming and solve blocks, then you cannot get by with express. Otherwise express should be fine alone, or with the help of this: https://community.ptc.com/t5/Mathcad/Prime-Express-A-joke/m-p/604216
I require the full version as we are using Solve Blocks and Symbolics. (symbolics in current module as used simplify and solve so far, but have seen solve blocks listed as an upcoming subject area so will require the full version.
