Changing the License Server for an Existing Mathcad Prime Install
cmcduffie
3-Newcomer
Is there a way to change the license server for an existing Mathcad Prime installation without using the GUI within Mathcad? I haven't found anything besides changing the XML file for silent installs, but that's only for before it is installed.
I'm able to achieve this for PTC Creo by changing a line in the parametric.psf file and would like to do something similar for Mathcad.
Using various versions of Mathcad- 9, 10 and 11.
Hi @cm_10543288,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
