Prime hat (bisher) nicht die Möglichkeit 0/0 zu definieren. Ist auch die Frage ob das jemals sein wird.
Wie Terry zeigt, muss jede Teilung in der der Nenner 0 sein könnte einen 'try' bekommen.
Viel Erfolg!
the Try command is only one approach to prevent this issue.
This is the knowledgebase article regarding current support on Division by Zero:
It says that in opposite to legacy Mathcad, in Mathcad Prime the division by zero must be actively handled. Multiple workarounds are possible.
In case it is not handled by the user's math itself, the system cannot prevent the user from running into an error automatically.
This is working as designed.
If you want to consider PTC to change this behavior, then please refer to Product Ideas @ PTC Community and consider posting a new one.
Note:
This is the English community. German support at PTC is available. Please file a new case:
Thank you for your understanding
