How to change the size of an already defined array.
cwenner-2
6-Contributor
I am using Mathcad Prime 5.0 5.0.0.0
I have a worksheet with an array that is 12 rows by 1 column. I know realize I want 15 rows. How can I change the arrays size so I can enter the additional values?
DhirajPatil
(To:cwenner-2)
Hi @cwenner-2
Please check the attached video.
cwenner-2
6-Contributor
(To:DhirajPatil)
Hi- that is fantastic in MathCADPrime. Good to know since I have a personal copy at home. However, the version we use at work is MathCAD 15.0! I did not see the same type of option under the >Insert menu, nor when I opened the "Matrix" tools.
cwenner-2
6-Contributor
(To:DhirajPatil)
Well son of a gun! I found how to use the insert matrix toolbar. I hadn't thought to enter a 0 for the column. I was leaving it blank. Thanks for leading me to the solution. Please close the support call.
