You possibly already have Prime 8 or 9 installed on your PC.
You cannot install Prime x when Prime x+N (where N>0) is installed. You have to install Prime versions in ascending order.
If this is your case, you could remove the higher versions from your PC and install 7, then 8 and/or 9.
Please show a screenshot of the error you are experiencing.
Please find attached a screenshot of the error.
No screenshot!
How could I add or attach a screen shot to the post?
