Prime Version 10
Two files did not convert as they contain locked areas
C:\Users\Terry\Downloads\Mathcad 15 files 2\Mathcad 15 files 2\Van der Waals fluid cycle with displacement R134 12.xmcd
C:\Users\Terry\Downloads\Mathcad 15 files 2\Mathcad 15 files 2\Van der Waals fluid cycle test 15.xmcd
The files as converted will need manual intervention as conversion program is not perfect.
Cheers
Terry
To use a Mathcad 15 file in Prime, the Mathcad 15 file needs to be converted to the Prime format.
A converter program is included with Prime but is not included in the default install so needs to be selected during install.
If it was not installed you may need to install again.
Otherwise zip up you mathcad 15 files and upload them here and we can translate them zip the and return them here. A large number of files can be converted at once.
Cheers
Terry
Thanks for the explanation.
I have installed the converter program. However, I still can't convert Mathcad 15 files.
When saving to HTML, the HTML status is "Not licensed".
So, could you convert some of my Mathcad 15 files?
They are attached.
Alexander
Hi Alexander,
No worries.
Just to check which version of Prime are you using?
Cheers
Terry
Prime Version 10
Cheers
Terry
