Mathcad does not start
JS_9776649
Mathcad does not start up. I have tried re-installing it without any luck. The start-up image shows for 1-2 seconds, then nothing happens
1 ACCEPTED SOLUTION
Hi JS_9776649,
Follow the below steps
  • Rename the file MathcadPrime.exe.Config to old_MathcadPrime.exe.Config  in the location "<C:\Program Data\PTC\Mathcad Prime>"
  • Rename the folder PTC to old_PTC in the location " C:\Users\%username%\Appdata\Local"
  • Clear temporary files on machine
Then launch Mathcad Prime 6.0 using administration privilege's
Vipul
6 REPLIES 6
What version on Mathcad?
JS_9776649
(To:VladimirN)
Prime 6.0
And Windows OS?
JS_9776649
(To:VladimirN)
Windows 10 Pro 64 Bit
Hi JS_9776649,
Vipul
JS_9776649
(To:VipulT)
Wow that worked perfectly. Thank you very much. You save a lot of work for me on my Bachelor Thesis now.
Thank you again!
Best regards
Jørgen
