Mathcad won't open beyond splash screen after unrelated crash
RC_7515533
2-Explorer
My computer crashed while using mathcad (unrelated crash to Mathcad). After restarting, Mathcad won't open beyond the splash screen. I have uninstalled and reinstalled the program, and keep getting the same results. Splash screen opens, closes, and then nothing else happens.
Tip - "Mathcad Prime does not launch after the initial splash on Windows OS": https://community.ptc.com/t5/Mathcad-Installation/Mathcad-Prime-does-not-launch-after-the-initial-splash-on/m-p/729884
Another one:
  • 1. Create a backup (or just archive) of the config file (in this directory: C:\Users\CurrentUser\AppData\Local\PTC\).
  • 2. Delete the current config file (in this directory: C:\Users\CurrentUser\AppData\Local\PTC\).
  • 3. Run Mathcad Prime again.
4 REPLIES 4
Another one:
Thank you.  The config file fixed it.
You're welcome.
I just encountered this same issue and this solution worked for me, except my directory slightly varied.
I found my config under: "C:\Users\CurrentUser\AppData\Local\PTC\MathcadPrime.exe_Url_...\9.0.0.0\user.config"
I moved it to desktop and restarted Mathcad Prime. I needed to revalidate my license and it works now. Compared the old and new configs and the old had a bunch of "null" where the new had setting lines; so it must have been corrupted.
I believe my issue was caused by leaving the Mathcad program running overnight on a weekend when my company shut off power for some electrical maintenance. This hard-shutdown prompted other windows issues on reboot and possibly corrupted my user.config file.
