Text is difficult to get exactly where you want it with the grid snapping, but you can resize the images in a much more precise way than moving the text around.
It is possible to use Windows Paint application to add Text of any size, font, and colour to an image without using grids.
Even fine tune the location of the text by moving it before pressing return to fix it..
Cheers
Terry
