Problem opening the software
ElichaiFrid
3-Newcomer
User ID: elihay.f@gmail.com
hey
I bought the software about two months ago
I learn and use it,
This morning I rebooted the computer and opened the software but it only opened the initial loading screen and then did not open the software,
I tried uninstalling the software and installing on a computer but it gave me the same problem.
I would like to know if you can help me open and use the software.
Thanks.
ELichai
Try the following tips:
Hello VladimirN
Thank you for your response.
I tried to solve the problem using the tips you provided in the response.
  1. . I couldn't find where to download the x32-Bit version of Mathcad Prime.
2. Cause: Bug with Windows security update KB4055002 for Microsoft.Net Framework 4.7.1 I tried uninstalling it, but the software still doesn't work.
When I run the setup file, it displays a green screen for 2 seconds, then closes the software. I have important material in the software that I urgently need to send.
I'm not very familiar with computer techniques.
Please help me find a way to successfully run the software again.
Thank you,
Have you tried the following steps:
1. Create a backup (or just archive) of the config file (in this directory: C:\Users\CurrentUser\AppData\Local\PTC\).
2. Delete the current config file (in this directory: C:\Users\CurrentUser\AppData\Local\PTC\).
3. Run Mathcad Prime again.
