Restoring the file
PW_14458485
2-Explorer
Restoring the file
I've saved the file on Mathcad Prime yesterday and today it's unable to be open. Unfortunately no restore file has been saved. Are you able to help with restoring the file?
LucMeekes
(To:PW_14458485)
Check if the file size is larger than 0. If that is the case, attach it. You may need to .zip it first and attach the .ZIP file.
