The result of any unit calculations are expressed in the base unit system of the calculation sheet. All you need do is change them to non-base units of your choice. For instance this sheet has the SI units as the base units of the sheet.
Cheers
Terry
Cheers
Terry
Hi @DD_14110366,
Anurag
