file
МЖ_9800869
file
file does not open
This thread is gaping any details including the Mathcad Product and version you are working with and the corrupted file to fix.
Assuming that the file got corrupted through a Save command, you'd better look out for a backup file to use.
However, it is in some cases possible to recover a corrupted Mathcad Prime worksheet - even with restrictions. But any data fix and/or investigation from PTC R&D department needs a PTC case to be filed.
Thank you for understanding.
