This is a common Windows error, usually indicating an issue with the installation file itself or the Windows Installer service on your computer.
Here are the solutions and steps you can try to fix this issue:
The most frequent cause is a corrupted or incomplete installer file.
Re-download: If possible, download the Mathcad installer package again directly from the official PTC website or the source you were given.
Check File Integrity: Ensure the size of the downloaded file matches the expected size (if provided).
Simple Location: Move the installer file to a simple location, such as your Desktop or the root of the C: drive (C:\), before running it. Long file paths can sometimes cause errors.
The installer might need elevated permissions to make necessary system changes.
Right-Click and Run: Right-click on the installation file (.exe or .msi) and select "Run as administrator."
The Windows service responsible for running .msi packages must be active.
Check Service Status:
Press the Windows key + R, type services.msc, and hit Enter.
Scroll down and find the service named "Windows Installer."
Make sure the Startup Type is set to Manual. If the Status is anything other than Running or if it's blank, right-click and select Start (or double-click and click Start).
If you downloaded the file from the internet, Windows might have flagged it as a security risk.
File Properties: Right-click the installation file and select "Properties."
In the General tab, look for a section at the bottom called Security. If you see a checkbox or button that says "Unblock," click it. Then, click Apply and OK.
Security software can sometimes incorrectly flag installation files, preventing them from opening or extracting correctly.
Temporary Disable: Temporarily disable your antivirus software and/or firewall (especially third-party ones) and try running the installer again. Remember to re-enable them immediately after your attempt.
1. ¿De qué versión del programa estás hablando?
2. ¿De dónde descargaste el programa?
Hi @CG_14388137,
Anurag
