Nothing is attached?
There is no reverse order that I know of. Simply set yplot:=0-y then plot x vs yplot..
Or export to excel to plot.
Cheers
Terry
you may wish to use the "reverse" function that "inverses" the order of elements in a vector or array. See the attached Mathcad 15 sheet.
HI @MR_9302175,
Please share the sample worksheet for further troubleshooting the issue
Vipul
I've already attached it to my previous post. This is what it looks like
"Troubleshooting" ?
This is what the OP wants (the plot to the right), as I understand it:
This is easily accomplished in ANY version of Mathcad
It's just NOT supported by (any version of) Prime, because Prime refuses to set the upper y-axis scale limit to a smaller value than the lower limit:
