when installing it said the servers were busy and that i couldnt go on with activating my license
MR_14325029
It mentioned problems with the server after putting in my product code so i tried again and it told me that i had used up all of my uses and now i dont know what to do. It said something about either the server being busy or something else
2 REPLIES 2
You need to contact PTC Customer Support for assistance with your Mathcad license activation. The messages you received—"server busy" followed by "used up all of my uses"—suggest a problem on the licensing server's side, possibly due to the initial unsuccessful activation attempt consuming one of your allowed uses.
Next Steps
  1. Do Not Try to Activate Again: Further attempts may lock your license completely.
  2. Contact PTC Technical Support: This is the only way to resolve the "used up all of my uses" error, as they can reset your license count on their server.
PTC Mathcad Support Contacts
You can usually get to the right support channel via the PTC Support Portal on their website. Look for a section dedicated to Installation and Licensing.
Region Installation and Licensing Contact
North America Use the Online Case Logger on the PTC Support Portal.
Europe Call 00800 PTC-4-HELP (00-800-78-24-43-57).
  • If you're in another region or need a local number, check the Mathcad Contacts page on the PTC Support website.
  • If you purchased Mathcad with a maintenance contract, ensure you have your Service Contract Number (SCN) or other account details ready, as this will expedite the support process.
Explain to the support representative:
  • The exact product and version you're trying to activate (e.g., Mathcad Prime 10).
  • Your Product Code or License Key.
  • The sequence of errors: the initial server/connection error, followed by the message that you've used up all your uses.
They will be able to verify your license and likely perform a manual reset or activation to fix the issue.
Hi @MR_14325029
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
