2 Equations symbolic system
mzampolla
Hi everybody, my name is Marcello and I am absolutely new with MathCad.
I succeded in solving a symbolic equation, now I want to know how to solve a symbolic system of 2 equations in x,y like the following:
x^2+y^2=r^2
y=mx+q
thanks in advance for your help
10 REPLIES 10
Like so:
Alan
Yes, it's exactly what I want to do!
How can I do the parentesis? Sorry for being a totally newbie...
Great!!! I succeded!!! Thanx a lot!
How can I do the parenthesis? Cannot see the reply.
I believe the "parenthesis" is actually an array (insert matrix)
(To:BillyBag2)
?? Not sure what exactly you mean and what you can't see.
In Prime you may simply type an opening square bracket [ and Prime will create a matrix. You can enlarge it vertically by pressing Shift Enter and horizontally by pressing Shift Space.
Thanks, thread contains question about adding parenthesis. Can see a thanks to the reply but no reply itself. Did not realise it was a matrix. All working now, thanks guys for your help.
One more question...when the system is solved I obviously get 2 results, how can I do to take one (the positive) result and to put into a graph?
In other worìds I want to put in a graph how x varies in relation to m and by expressing m=tan(α) how x and y change in relation to α.
Do you mean something like this (obviously, I've made up the numbers):
Alan
Yes, Alan you are great!
