2D to 3D
Raiko
2D to 3D
Hello folks,
does anybody know how to turn this oiecewise defined graph into a 3D plot?
Thanks in advance
Raiko
8 REPLIES 8
Valery and Werner
thank you both for your response.
I just noticed that I had a typo in my message "oiecewise" instead of "piecewise". What I meant was the following:
To display one function is simple, but how do I define two consecutive functions that can be displayed in one 3D graph? f(x) and h(x) in my instance.
For that I do need advice
Raiko
Fred_Kohlhepp
23-Emerald I
(To:Raiko)
You have two functions of one variable:  f(x) and h(x).  For a three-dimensional plot you need to specify the dependence on a second variable.  f(x,y) and h(x,y).
Otherwise they're planar functions on an unspecified value of y.
What am I missing?  Something like this?
(To:Raiko)
In Mathcad 15 you could use onerror similiar to what Valery had shown, but I would not return 0 in case of an error but rather a value like -10^(-8).
In Prime I would return NaN in case of error (unfortunately Mathcad 15 does not accept NaN in 3D plots).
You may also consider to simply chose a mesh which avoids zero values for x or y:
Regards
Werner
(To:Raiko)
??? Sorry, but I don't understand what you are looking for.
How would you like to plot a function fx)  in one independend variable (piecewise or not) into a 3D??
Fred had rotated your piciewise function around the z-axis.
I did something similar to what you tried with q(x,y)
WE
(To:Raiko)
Oh,  just now noticed that you tried to define a function M further down.
You defined local functions M instead of assigning the result a local variable M (you may chose any other name here).
Furthermore your condition was faulty. You cannot write "(x AND y)>1" but have to write "x>1 AND y>1". At least I guess that this is what you had in mind.
But your logic seems to be faulty - I guess you had something different in mind that what you get here.
Just image where in the xy-plane the points are, where both x and y are either >1 or both are <1!
Werner
Raiko
(To:Werner_E)
Thank you all for helping
Raiko
