On 6/30/2009 4:11:13 PM, drhogue wrote:
>...That default
>value of -5 to 5 was it. I
>thought it was using the
>values that I assigned to the
>variables.
______________________________
The default values are those from the mesh default 20, thus getting a 0 value in the default range of � 5. So, mesh odd number like 19, 21. If you want to have it ranged and meshed externally, then use the function "Createmesh". That will also give you an export, which export you don't have from the quickplot.
jmG
