I'm stuck with 3D scatter plot.
I have x, y and z final values to plot. I have manged to plot them, but since z is depth, I have to reverse the z axis by pointing it 'south'. In 2D plots i've just reversed the scale and the axis plot was reversed.
attached is the data sample, mathcad 14.0
Ideas? except making the z values -ve . . .
thank you!
Mike,
Open the settings dialog box from the plot and set Tilt to 180 degrees, then rotate to get the view you want. I think that should work.
Stuart
