About matrix definition
- May 6, 2015
- 3 replies
- 2946 views
Hi, i suppose my problem has a easy solution, but I cant find it.
I define a simple operation k(B), I got the results but by some circunstance I got a solution that I need to change, so I want to create a new matrix with the modified results and call it back to use it on an equation but I wrong results... (image attached)..
As you can see in the image, when I select the new matrix, I can not change the Math Properties (Tab).
Hope you can help me.
