I'm using the given - find solve a series of equations and the number of variable that are being solved for has resulted in the find statement being longer than the page width, is there a simply way to get this onto one page width, ie on a second line etc. before I start to look at changing the variable names or possibly carrying out some substitution in the equations to reduce the number of solve variable's. I'm Using Mathcad 15. Thanks.
No.
You can break up some equations, if they have a series of addition/subtractions, by using ctl-Enter, which allows you to have parts of the expression on separate lines. Otherwise, I'm afraid you're stuck with finding ways round it, such as Landscape rather then Portrait page orientation or using vectors to hold some of the variables.
Stuart
Cheers Stuart. I thought as much, but just thought I'd ask!
