Add Limit Bar or region to a 2D plot
dsicking
Often data plotted or functions have end uses which showing acceptable range is importand. Older versions allowed entering a constant function among the traces. Mathcad 14 doesn't seem to do this. How does one accomplish the function?
RichardJ
(To:dsicking)
Do the markers not do what You need?
Can you give an example of the format that you would like to achieve?
A picture would probably suffice ,but a few words to explain might be helpful.
