Often data plotted or functions have end uses which showing acceptable range is importand. Older versions allowed entering a constant function among the traces. Mathcad 14 doesn't seem to do this. How does one accomplish the function?
Do the markers not do what You need?
Can you give an example of the format that you would like to achieve?
A picture would probably suffice ,but a few words to explain might be helpful.
