Hello!!
Add button
What is the Code equivalent for Cltr+F9 to be placed in my “Sub PushBtnEvent_Start()” procedure, see below:
Dim state
Rem TODO: Add your code here
End Sub
Sub PushBtnEvent_Exec(Inputs,Outputs)
Outputs(0).value = state
End Sub
Sub PushBtnEvent_Stop()
End Sub
Sub PushBtn_Click()
If state = 0 Then
state = 1
Else
state = 0
End If
PushBtn.Recalculate()
End Sub
thanks!!
The Start and Stop procedures are essentially obsolete. You should ignore them.
You are probably looking for the Worksheet.Recalculate method. What exactly are you trying to do?
