On 10/20/2009 4:12:02 AM, KristjanLaes wrote:
>Hello!
>I would like to have a fit for
>the current-voltage curve of
>one Schottky junction
>(probably this is, or may be).
>The problem is that the
>equation for real solar cell
>that may be used here, has not
>have an explicit form.
>How to fit the data using such
>an equation?
>KL_______________________________
Your model is wrong, you don't have a circuit to look at it ... J0 is Bessel built-in, rather use Jsubscript. A very similar work was done for other collab, please use same symbology as much as you can ... NOT k*T but kT where kT is defined , what about q ? k ? That there is a solution (W) to a wrong model will not correct the model. It does not Minerr, does not Given/Find.
Start from the model that more collab can look at. I will not attempt to fit a function, and the rational model will glitch ! DeadLock !
jmG
