Application.ActiveWorksheet returns nothing
epainter
I am embedding some VB in a Scripted Object within a MathCad worksheet. I am trying to get the Worksheet object so I can get/manipulate some values in the sheet, but when I call ActiveWorksheet (or Worksheets for that matter) on the Application object, nothing is returned.
I am inexperienced with VB so forgive anything weird I am doing, but feel free to point it out. Here is what I have basically. I get an error object worksheet is required on the last line of the Sub.
Sub getValueEvent_Exec(Inputs,Outputs)
  Dim objMC
  Dim value
  Dim worksheet
  Set objMC = CreateObject("MathCad.Application")
  Set worksheet =objMC.ActiveWorksheet
  Set value = worksheet.getValue("value")
End Sub
Evan
StuartBruff
(To:epainter)
  Dim objMC
  Dim value
  Dim worksheet
End Sub
Can I just clarify what you're doing here?  You are working inside Mathcad. You have create a worksheet and have added a component (TextBox, ListBox, etc) to the worksheet and are now trying to work with the script inside that component?
Is so, the current worksheet is defined by default and simply named worksheet, so you don't have to go through the rigmarole of creating a Mathcad object.
Stuart
StuartBruff
(To:epainter)
  Dim objMC
  Dim value
  Dim worksheet
End Sub
Stuart
Perfect! Yeah your assessment of what I was doing is correct. I was making it much harder than it needed to be. Thanks for the help!
StuartBruff
(To:epainter)
No worries.  I think most of us have had to bang our heads against the difficulty of finding out how to use scripting when all we've got to go on is the documentation!
Stuart
