to all
(Re-posting as I had some issue updating the original post)
I have go to sets of data points representing a cross section in an undeformed and deformed state. I would like to get the change of area descbired by the points. I have read the data in mcad and plotted them on a graph. So far so good.
I am struggling with the use of the cspline() and interp() and would appreciate some pointers
JXB
You should have cross posted. You could have just posted the data underneath.
Mike
Comment about Fred's comment, you don't need to rotate, can integrate about the y axis just as about the x axis.
Numerically integrating double integrals is very slow, because for every integration point of the second integration, the first integral must be numerically evaluated up to that point. That is a lot of integrations.
But, think of a horizontal strip dy high and with of b(y)=Right(x)-Left(x), and then integrate that.
Managed to integrate using a "rotated" approach. I am looking for a wa of posting the updated mcad sheet but under "Actions" I do not get the usual "Update post". Thanks to all for the suggestions
To post a sheet (or to reply only once) I have to "use advanced editor" in the upper right corner of the reply block.
