Area inscribed by points ?
JBlackhole
to all
(Re-posting as I had some issue updating the original post)
I have go to sets of data points representing a cross section in an undeformed and deformed state. I would like to get the change of area descbired by the points. I have read the data in mcad and plotted them on a graph. So far so good.
I am struggling with the use of the cspline() and interp() and would appreciate some pointers
JXB
5 REPLIES 5
You should have cross posted. You could have just posted the data underneath.
Mike
executed
wayne
(To:JBlackhole)
Comment about Fred's comment, you don't need to rotate, can integrate about the y axis just as about the x axis.
Numerically integrating double integrals is very slow, because for every integration point of the second integration, the first integral must be numerically evaluated up to that point. That is a lot of integrations.
But, think of a horizontal strip dy high and with of b(y)=Right(x)-Left(x), and then integrate that.
Managed to integrate using a "rotated" approach. I am looking for a wa of posting the updated mcad sheet but under "Actions" I do not get the usual "Update post". Thanks to all for the suggestions
To post a sheet (or to reply only once) I have to "use advanced editor" in the upper right corner of the reply block.
