Not sure if this is even possible with Mathcad but thought I'd ask the question.
I have several collapsible areas on a mathcad file. Depending on a answer from a formula at the start of the mathcad file some of the calculations would be irrelevant and are therefore hidden in collapsible areas.
i.e. if the answer is >10 then all fomulas are applicable If not then 3 areas are not required and these are generally hidden.
Is there a way of autohiding collapsible areas based on a given answer from a formula?
Unfortunately I do not think this is possible. There a few other approaches which may help.
This has been asked a number of times, and as Mike says, it's not possible.
I use for this on my Mathcad Server... pictures.
See please http://twtmas.mpei.ac.ru/mas/Worksheets/IF_in_WorkSheet.mcd
I can show one set of operators or other.
Others same calculations
http://twt.mpei.ac.ru/MCS/Worksheets/Hydro/GDF.xmcd
http://twt.mpei.ac.ru/MCS/Worksheets/Chem/CRC.xmcd
We see one or others formulas or set of formulas depended of values of variables.
You could use a TOC of contents to jump to the collapsed area you want to use. Not the best workaround but may help.
If Gareth would use Prime he would not be able to use hyperlinks but from what I remember he is using MC14.
As far as I recall we cannot jump to/inside a collapsed area via hyperlink. Furthermore you can't make the hyperlink dependent on the result of a calculation.
You could jump to a region and the hyperlink could be selected by the user following the result from a calculation. Text instructions could be dependant on a calculation?
Not sure if this would be close to what Gareth had in mind.
And text instructions sure could be dependent on a calculation. Either by normal string evaluation or by a scripted component.
We would need a concrete example as to what should be achieved, but I fear we wouldn't come close enough as it looks to me that Gareth wants to show/hide specific calculation steps and not only the results.
I fear you maybe correct. I was just trying to sound positive
Thanks Guys. The only solution I could think of was the hyperlinks and close and open the collapsible areas manual. I wasn't sure if you could somehow programme a command but that is way out of my depth.
Its a shame PTC hasn't addressed this as it could help the user produce a more efficient Mathcad output and save time.
Yes you are correct and as said above, you could point the user to the collapsed area but they would have to manually open the region, which isn't that taxing.
I wouldn't hold your breath for this being implemented into Prime any time soon.
