Hello!
Is it possible to find value from graph automatically... For example if I enter distance value from beam edge 2m them I can get shear value in that point automatically... I know that with trace command it is possible to do it manually (see that value) but is it possible to find that value somehow automatically...
Thank you,
Marek
You can fit a function to your plotting vectors, then evaluate the function at any ponit you want.
Thank you for your trouble and worthy advice, it helps a lot!!!
